Will this single mount manifold work well? or is it junk?
KrS24
Similar to the MOTIV manifold. It should work.
If you want to use an external wastegate the manifold needs to be modified.
Be prepared to replace o2 sensor's frequently.
JayDrft
looked at the manifold - Im no expert, but Ive been given the tip, that at least one exhaust port from the head, should line up with the inlet of the turbo exhaust intake.
Apparently the reason for this is that there is always a constant pulse into the turbo during ignition variation. Makes complete sense - the setup you showed is centered...
This is my understanding - A lot of your big horsepower CAT engines run this format of manifold.
