WHY SO LOW.
Stephanv
Hi guys.
just a quick Q, is there anyone else that also has this problem with ground clearance? My car is so :argh: low that is scrapes on every thing.
does anyone else have this problem. My car is still on it's std suspension as far as i know.
thanks gents.
Cole
depends on which model you drive, my girlfriends 1 series was very low compared to my e90, her car would grind on things even if you went over at an angle where the e90 sailed over it....
UpNcOmiNg!
Events Organiser
well I know thats about right for the touring with the sports pack.
Friend has the 325i, sits the same
abmi0000
your car doesn't look low enough to be scrapping all over the place. Think the stuff you are going over is just too high.
Put 20's on the car and you're sorted
CyberMatix
Stephanv said:
2003 318i touring.
see pic
From the pics it looks like it's sitting a bit lower at the rear. Did you ever change tyres, perhaps to ones with a lower profile or lower OD? Even half an inch on OD can make a difference.
There are ways to solve the problem - I'm sure the suspension gurus can perhaps help - you can perhaps increase the ride height by 0.5" by inserting some spacers.
The are some devices that the guys with low ride height cars like Porche install that can lift the car by up to 50mm at a flick of a switch. But very expensive.
Or you can fit tyres with a slightly higher OD.
Or earplugs, so you won't hear the scraping.
abmi0000
Like Cyber said - get some spacers. This is your cheapest option. Around R70 a set.
Check your shocks too.
ride height looks right to me... if there is nothing hanging off the bottom then thats just how it is sorry :(
my e46 is way better over stuff than my old polo was :rollsmile:
Stephanv
i know. but trust me it does. ill take a pic of how low it is getting into the garrage. here it is outside not that steep and it doesn't scrape when i pull it in but very close.
and regarding the 20's the wife says no as it's here dd. but if i buy them and fit them she cant :argh:. :rollsmile::rollsmile::rollsmile:
is it possible that the wheel base is a bit 2long with regards to the sport pack's lowerd suspension?
abmi0000
You'll be in the dog box for a bit but the wheels will be around for MUCH longer :grin:
Stephanv
Wick-ed said:
What is the body weight inside the car?
in front me the wife
and in back 1 4year old 1 1 yaer old and empty boot.
so no weight.
:biglol::thumbs:
J
Jandre
My 540's ass is also pretty low. Those springs have seen better days. I need to replace them soon. It's getting damn irritating.
Had to ask a Toureg owner to pull his car out of the driveway on Sunday. So that I can use the entire driveway just to get my car out without breaking the back off.
Rambam
Stephanv said:
Hi guys.
thanks gents.
HAHAHAA I read Why so slow :rollsmile:
Stephanv
Rambam said:
Stephanv said:
Hi guys.
thanks gents.
:roflol::roflol::roflol:
the auto is not slow. just f@#$%ing low
CyberMatix
so no weight.
Quite simple really:
1) Get rid of the kids (maybe the wife too).
2) Fill the rear seats and boot with helium filled balloons.
QED
