Wheel Bearings?????
Tlvivo
Hi Fanatics - Compliments of the new year!!
So I recently changed my tyres - a coupla km's after I started hearing that winning noise (wooowoooowooooo). So i immediately thought tyres - changed the tyres put on the old pair - same noise - the noise increases as u speed up. So I then thought wheel bearings - is there any indicative measure that I can use to check this???
On a measure of 1 - 10 how hard can this be on DYI?
i was looking at doing mine and after doing the research i decided to let my mech do it they dont charge much for it... maybe next time ill change my mind about it :dunno:
iifunky
Heya
There is a tutorial some where on this. But i say leave it to the professionals especially if you don't have the tools.
Google the tut.
Cheers
Tlvivo
Professionals it is... thanks guys - i know you need some sort of bearing tool to pull them out.
Hellas
on a 1 to 10 it's an 11. Ok, not so much, but it's definitely not a home DIY. Specialized tools required to safely pull off the old bearing and place the new ones. There are DIY's on the net. Search a bit then you decide. I did bearings on my polo, but that was like changing a bicycle bearing. The E46 has a bit beefier bearing at the back and I decided to outsource.
Tlvivo
Howzit peeps - believe it or not I have still not done this.
So today i decided to call the stealer for some prices - front wheel bearing comes complete with hub R1272 incl VAT per side....
Is there a another around this? Suggestions please Jan budget is tight, GIZMO any recommendations - could you quote me for fitment if I purchased the bearings from BMG?
when i did my rear bearing it totaled 1k including fitting i think the front ones are cheaper...
Tlvivo
Seems front ones are more expensive
R629.03 each BMG
R763.00 each Autozone
R195 each Midas Midway (not sure if they are giving correct info)
R1272 complete hub each BMW
type 1 - R550ea type 2 - R260ea Midas Randburg
Philip Foglar
And believe it or not, still cheaper than a rear bearing/hub assy for a '99 model Toyota Corolla - and that was some years ago too!!
