Wheel Alignment - Hyperli deal
SanM
Hi Fanatics
That time of the year again, and I need to get my wheel alignment done. I came across this deal at Hyperli, R99 for alignment, and R175 for alignment and balancing. It's at Supa Quik in Ferndale.
https://www.hyperli.com/products/3d...tional-treatments-at-supa-quick-randburg/2043
I need to do it on my m135i. It's quite affordable, so I would like to know if any of you have tried them out? Is there anything I should be wary of, or anything I should specify to them before proceeding?
BMW wheel alignment is now over R1000, and it's not even covered under maintenance plan, so that's out of the question.
Alternatively, if there's a garage or workshop that you can recommend, I'd appreciate it. I work in the Parktown area.
Solo Man
I am down in Hermanus so cannot comment on work up in Gauteng. Had my X3 wheel alignment done yesterday. Four wheel alignment. Stood by to see that it is done properly. Was R400 at Hi-Q. You are getting a bargain at R99. Just check the work!
SanM
They mentioned that they may have an issue with my car as it may be too low for their equipment. That is strange since my car is on stock suspension and springs. They mentioned a guy came with his 235i and they weren't able to do it.
Will have to see for myself. Guess it is too good to be true.
Andre1983
Wow @soloman , i was there about 2 weeks ago and they charged me R600 for my e90....
Sent from my SM-J720F using Tapatalk
tman
Ive used this voucher at least 5 times in the last few years. Nothing wrong with it.
The only catch is they only redeem codes at times they not busy, so you cant go on a Saturday morning for example.
SanM
Just an update. Got my wheel alignment done at Evolution Wheel & Tyre, at Booysens. Good service and a professional job. They're currently running a special, which does alignment & balancing for R230. I added nitrogen for an additional R120.
Great deal. If you go, feel free to mention my name (San, with the m135i) as a referral.
