Water/Meth turbulence in my boot
Twinz
Forum - Support
Was bored and decided to do a quick video of the water/meth turbulence that happens in the boot during varied driving.
A couple of lessons:
1. Tank must be properly mounted to withstand the hectic movement in the boot. The squeaks you hear come from the nitrous bottles on the left hand side...:=):
2. If the water/meth level becomes too low due to the constant sloshing the low level float switch may pick-up air and communicate wrong readings to the flow sensor.
3. If tank is not properly closed it will leak all over your boot carpet.
:ty:
<iframe width="560" height="315" src="
" frameborder="0" allowfullscreen></iframe>
Mr Occo
Couldn't you integrate some sort of baffle system in the tank?
Just a thought?
Would love a closer look at the car on next ct run.....
Twinz
Forum - Support
This particular tank has a baffle section. The pump rests on it and the pick-up tube is tapped into it. But air pick up is still possible if levels drop very low. My tank will never run empty because i regularly check for a top-up.
Mr Occo
Hmmmm, me thinks of a reserve loop back system to be sorting that problem, I'll see, if you want, if I can get hold of a buddy of mine he designs these sort of tanks and so on. I'm sure the principle is the same.
Twinz
Forum - Support
Your buddy has just gotten another buddy.
I have three summer projects:
1. A new exhaust design for my car and off with the mufflers.
2. A new meth tank design. I have some design concepts already. Time for your buddy and i to put our heads together.
3. Waiting for the new M3 to be launched. I will travel wherever to go and view this car. :thumbs:
outlaw335
I would never even think of doing a test like this :bravo: Very interesting to see what goes on there,especially on pull away.I dont have a low level switch but i always make sure my levels are ok
Twinz
Forum - Support
Thx.
Because the JB4 controls your flow it does not need a flow sensor or float switch. :thumbs:
I use an external controller CMGS gauge and need the additional failsafes. :thumbs:
