akash said:I would try and salvage what you have. Would silicone gasket maker not help?
sunnyj said:akash said:I would try and salvage what you have. Would silicone gasket maker not help?
Perhaps but I have not had this sort of problem before so am not sure. Has anyone used silicone gasket maker to sort out any water in lens issues?
Iceman007 said:sunnyj said:akash said:I would try and salvage what you have. Would silicone gasket maker not help?
Usually all they use is high density foam matt 4mm or 5mm thick that you can get at any rubber product place and cut out the gascket
Tris said:I knew a laaitjie once who had the same problem over and over who eventually heated a thin piece of wire and made a tiny hole at the bottom of the lens so the water drained out via the hole
Not the best fix, but it worked
sunnyj said:Tris said:I knew a laaitjie once who had the same problem over and over who eventually heated a thin piece of wire and made a tiny hole at the bottom of the lens so the water drained out via the hole
On what vehicle was this?
The thing is if the tail light lens gets stuffed then it'll cost more to replace that than the actual gasket. I'm actually leaning towards putting in new gaskets. I just hope the new one's are better than the ones originally fitted.Tris said:sunnyj said:Tris said:I knew a laaitjie once who had the same problem over and over who eventually heated a thin piece of wire and made a tiny hole at the bottom of the lens so the water drained out via the hole
Mk1 jetta/fox
