Davin135 said:M3_devil said:Correction. Forge sells waste gate actuators.
Issue is with wastegate flap which is part of the turbo housing.
Thanks KRS24.
M3_devil so u recommend I just replace the turbos?
replacement of the turbos would be the best and most logical choice as tightening up the actuator rods mostly dont yield any positive results because the bush in the exhaust housing that the wastegate runs on wears and as a result the flap doesnt close tightly anymore...
fresh turbos are also a pleasure to drive...
ps. i did some phoning around end of 2014 and was quoted approx 2/3k per turbo to completely overhaul my old turbos with new parts as long as the housing wasnt damaged. they are Mitsubishi tdo3 based and genuine parts are easily available.
pps. i also spoke to a fellow fanatic who paid in the region of 25 or 28k to have his turbos's "upgraded" while serviced with no appreciable increase in power, so beware when promises of better performance is being tossed around.
