+1 on all ground/earth wire.
There is also a small probability that it could be an old (working) bulb causing the problem too. As the bulbs age, their resistance increases and they appear to be detected as blown, even though they are working.
If the warning light is on one side only, swap all the bulbs over and then check what happens.
However, 90% chance that it is the ground wire.
