VSOMAI in GP
DieselFan
wikked said:
vsomai said:
wikked said:
i have not imported these as yet but i have a reputable supplier who i buy other items from. what sizes or for what vehicle are you interested in?
E36.
Keen on these specifically as you can get the halo's to act as your indicators
AFAIK they will not fit properly. With the e46 you would have to fit them around the projector shroud. Which was not good for me. And the highbean is flat on the top so it would not have worked for the highbeam. You're better off with a set made specifically for your car.
I had a set and sent them back.
wikked
Banned
DieselFan said:
wikked said:
vsomai said:
E36.
DieselFan
wikked said:
DieselFan said:
wikked said:
vsomai said:
E36.
Sorry dude :)
Nastaliq
Howsit Vish,
Looking for the lights (LED) for an F10 for inside the boot, NOT the numberplate light.
I have no desire to make my number plate more visible, but have found the light dim inside the boot.
There are 2, one goes on the inside of the bootlid, the other goes deeper into the non-moving part of the boot.
vishal@somaitech
wikked said:
vsomai said:
E36.
a set of 4 rings and 4 voltage drivers is R1050
these rings give off white light and have a warranty of 6 months.
they are also specifically made to fit the E36
vishal@somaitech
Nastaliq said:
Howsit Vish,
Hey bud,
according to bmwfans.info the part number for these bulbs are 63217160912
i have the LED bulb replacements for them that are bright. one is canbus with 8smd5050 led and the other is non-canbus with 9smd5050 led. each one is R80.
Regards,
Vishal
Dean ///M
Limited Profile
How do I remove the oem bulb I see that it pushes down and turns but refuses to come out. Has anyone successfully done this without any error codes?
vishal@somaitech
the actual bulb fits into a plastic housing. this plastic housing is melted onto the base of the reflector bowl. it is not possible to remove the actual bulb from the top of the reflector bowl. therefore you have to melt off (with a soldering iron) the tabs on the plastic housing and remove it with the bulb. after replacing the bulb you can reverse this process and melt some plastic (obtained from elsewhere) to re-secure it.
i did this to an E90 bulb once it worked well.
let me know if you try this.
Nastaliq
vsomai said:
Nastaliq said:
Howsit Vish,
Hey bud,
Regards,
Vishal
Okay, how does it work?
Will you bring them up, i meet you, pay and you fit?
or do i pay beforehand and you bring, where do i collect etc?
AshG108
vsomai said:
Nastaliq said:
Howsit Vish,
Hey bud,
Regards,
Vishal
howsit Vish,
I need LED light for the boot of my E90 as well, cna you bring 2 for me please. also, if you have for inside the cabin as well, please let me know the price.
vishal@somaitech
Nastaliq said:
vsomai said:
Nastaliq said:
Howsit Vish,
Hey bud,
Regards,
Vishal
please send me your number. i will contact you when i am there. you can pay cash after fitting. Thanks
Nastaliq
vsomai said:
Nastaliq said:
vsomai said:
Nastaliq said:
Howsit Vish,
Hey bud,
Regards,
Vishal
PM Sent.
Thanks.
vishal@somaitech
AshG108 said:
vsomai said:
Nastaliq said:
Howsit Vish,
Hey bud,
Regards,
Vishal
howsit Vish,
i will certainly bring them up. the price for non canbus LED bulbs (festoon and T10) are R50 each. the canbus ones are R80 each.
AshG108
vsomai said:
AshG108 said:
vsomai said:
Nastaliq said:
Howsit Vish,
Hey bud,
Regards,
Vishal
howsit Vish,
Will take canbus bud, thank you!
vishal@somaitech
after many queries about LED bulbs i thought it would be nice to show what i have in stock at the moment.
vishal@somaitech
It was good meeting so many fellow fanatics for the first time.
Thanks a lot guys!
Sent from my HUAWEI P7-L00 using Tapatalk 2
