Vanos m50
danieljames
Hi fanatics. So I've been searching and reading a few posts with regards to vanos diy.....
my vanos is very rattly....even at idle. The motor in question is an m50b25. 270k km.
My question tho.... will replacing the seals help to get her purring like a kitten again or am I facing something waaaaay more expensive?
sent from... a phone
Rooi_Willie
Get hold of the Axis guys. They seem to be the vanos kings on the forum :rollsmile:
Sent from my SM-N9005 using Tapatalk
Peter@AEW
If the vanos is "rattly" you may require the rattle kit installed as well.
Typically the M50 does not suffer from rattles on the vanos so it could well be something else.
The seal kit is available from "moranor" as is the rattle kit.
danieljames
Thanks guys. My car stands during the week so at least she won't get worse. I'll look into it ASAP. With regards to the locking tool....is that only available at the stealers?.
Rodney///Marsh
DJ - my buddy had the similar issue with his 328i. ended up making a bullet hole in the motor. apparently something to do the chain guides and tensioners and the chain was too loose and caused the rattle and something broke and there you go, broken engine.
danieljames
Thanks for the motivation lol. I'm waiting on quotes from a few garages. I'll keep the forum posted with regards to results
