Using the manual override on my sunroof? 635 CSi
NewB MW
So guys I have not been able to get the sunroof to slide into position correctly, and rain is coming. On Monday I had to stay at the shop parked underground till the rain stopped :thumbdo: I have two questions.
1: I think the headliner on the sunroof is on the wrong way around...There is a seam line at the front and logic tells me it should be at the back for the tilt option. Where are you seam lines?
2: Located next to the sunroof switch is the plastic covering that as far as I have read is the manual override for the sunroof. I popped that open and the mechanism is cover with leather...??? What the heck?? Is this where the manual closing system is located? I really dont want to cut through the leather and then I have stuffed up the headliner.
Clownshoe
From Bigcoupe.com
[undefined=undefined]Redo My Sunroof Headliner Upholstery
1. Leave your ignition off and use the manual Sunroof operation procedures (This will lessen the chance of significant damage to your drives worms): Use the sparkplug wrench to loosen the large nut on the motor. Then use the allen wrench tool to open and close the Sunroof by turning the fitting within the large nut. Wedge the allen wrench in with some paper wadding or such to keep it from falling down every 15 seconds (drove me NUTS for a while).
2. Open the Sunroof. From outside the car, unscrew three screws from each side's guide rails and two screws from a bracket just behind them on each side as well. Make note of (mark) the position of the raised little ramp on each bracket. They are separate pieces and will come free once you remove the brackets.
3. Carefully crank the Sunroof forward until it's just a couple of inches open and release the Headliner from it by pulling down on the front edge to release about six door panel type plugs/clips. Use of a strong, smooth, curved device to pry the clips away will prevent possible damage. Or just go to your parts store and buy a "Door Panel Tool" (Approx. $8.00). Slide the Headliner all the way back.
4. Slowly close the Sunroof. Remove three small nuts and washers from under each side of the Sunroof. They are arranged in a triangular pattern on triangular brackets. Release the brackets from the studs which are attached to the Sunroof. You may now remove the Sunroof by simply raising it from the inside and lifting it off from the outside. A second person used here or some nice shop blankets will ensure no uninvited "engraving" on your roof.
5. Pull the Headliner all the way forward. It will be attached to a transverse rail by a rod on each side. The rods can not be disconnected from the Headliner, but they can be disconnected from the rail by gently prying them down. A little clip and rod just disengage. You can now remove the Headliner.
6. To install: place the Headliner on its slides and snap the rod ends into the clips on the transverse rail. (By the way, if you should have decided to remove the rail, remember to have the pointy ends facing forward when you re-install it.) Slide the Headliner all the way back.
7. Place the Sunroof back on the car. Before doing this, take the time to lube your rear seals, as this will be the last time you'll see them for a while (hopefully!) The end of the roof with "the little skis" on each side is the front. If you've moved the mounts just reposition them with the allen wrench crank. Install the three mounting nuts and washers on each side.
8. This is a good time to adjust the Sunroof height if desired. The two screws that are attached to the sides of the triangular mounting plates are used to adjust the height of the rear of the Sunroof, which should be 1mm ABOVE the height of the roof behind it. The three screws across each front corner are used to control the front height, which should be 1mm BELOW the height of the roof in front of it. Loosen both sets of inner screws then turn each outer screw to adjust the height while pressing down on the Sunroof. Re-tighten the two inner screws on each side to lock the setting in. You won't believe the difference in Wind Noise a properly adjusted Sunroof can make.
8. Here's where my procedures differ from the books a little, but trust me, THIS will save you mucho frustration. This extra procedure is to re-engage the Headliner's followers with the rails on the Sunroof itself, so that the Headliner follows the Sunroof when it's placed into the "Raised" position. Slowly, while pushing back on the roof to keep tension on the drive cables, crank the roof back far enough to re-install the guide rails and their three screws. Don't worry about the brackets yet. Now crank the roof about three fourths of the way forward.
9. GO WASH YOUR HANDS. Slide the headliner forward until the clips line up with their holes. A good pull on the front edge while gently pushing from inside will make this a bit easier. Snap all the clips home. Return the Sunroof to the full aft position.
10. Being as you're in this "Mode", now would be a good time to remove the guide rails again and lube the rails and drive cables. My book recommends Vasoline for the rails and light grease for the cables. Do this AFTER you're finished handling the headliner. This avoids the need for "Post Procedure Upholstery Cleaner" to remove all your greasy finger marks. Replace the guide rails and brackets, AND their little ramps, returning the ramps to their original position.
11. Carefully crank the sunroof a little past full forward to make sure the headliner raises along with the sunroof. If it does, you're just about finished! Congrats. If it doesn't, return the sunroof to a "Closed" position, GO WASH YOUR HANDS, then disengage the headliner from the sunroof (Step Three above), slide it back, and pull it forward again while gently pressing upward on the rear of the headliner as it comes forward. Test the "Raised" position again. Done. (I Hope!)
12. Now re-tighten the large nut by the drive motor with your sparkplug wrench. It doesn't matter where in the cycle the Sunroof is, as it is the position of the drive cables that controls motor function. Turn on your ignition and see if it works.
[/undefined]
