Dylan dos santos said:
Hi guys , i recently purchased new rims and tires for my 330d e90 lci. They are 19s HRE reps with front yokohama f1's and rear achilles(265/30). This is the second time this has happened in a short while and is a huge irritation.
The rim spins inside the tire and goes out of balance when pushing the car!
The tire is at the correct pressure and the correct size for the rim.
:bangdesk:
Please help with any suggestions?
Thanks a lot!
under "hard" acceleration, or under "hard" braking ?
On aircraft there are "creep" marks, red-painted line running from the tyre onto the rim, and is a pre-flight item, mainly because aircraft still use inner tubes and the associated risk of dragging the inner tube until it rips the valve out.
Achilles is not a bad tyre, but it could be that it isn't up to the job of your "spirited" driving style.
You could try the "bead glue" option, and/or you could try to slightly roughen the matching surfaces between the bead and the rim lip, and then increase the tyre pressure slightly...to allow for a better mating/gripping surface action.
alternatively buy a set of tyres for the rear that are truly up to the job of you spirited driving style
or drive like an "old" man....like me !
