maverick328
Hi everyone,
I recently noticed that my high speed fan is kicking in within a few minutes of driving. I drive an E90 330d LCI. I had the car scanned for errors and nothing related came up.
This afternoon on the drive back home from the mechanic the car threw a engine temp amber warning and then the car went into limp mode. I pulled over and waited a while then started up again, amber light was off but car still in limp mode.
Got home and used my OBD scanner to check coolant temp and it was 115 deg C.
Observations over the last few days:
Any idea what the issue is?
G
- The coolant bleed process is not working, I can hear the pump running but no coolant running into expansion tank
- High speed fan kicks in with aircon off
- Car goes into limp mode when coolant temp goes to 115 deg
- Coolant level dropped over the last 6 days (topped up twice)
- Coolant overflow works when car is idling
G
