its a 3.4% difference... too much for my liking, unless going bigger in the rear.Gunner-Win said:That will decrease the height of the side wall. So it will mean the car will sit slightly lower, ride will be slightly harder, and the rim will be more likely to get damaged due to there being less tyre between the road and rim.
At the same time the rolling circumference of the tyre will change. The rolling circumference will decrease very slightly resulting in more acceleration and less top speed. Although the difference will be very slight.
It will also mean your speedometer reading will change. So if before the change your speedo said 105 and your gps said 100, it might change to speedo speed of 105 and gps to96 for example.
Edit to add: Use this website for any tyre change information you need:
http://www.willtheyfit.com/
Hugo_za said:I've gotten quotes from BMW for OEM and have also asked Ralf to quote as well.
Ralf@Speedway Motorsport said:Hugo_za said:I've gotten quotes from BMW for OEM and have also asked Ralf to quote as well.
will that be RFT or STANDARD ?
I am on "good terms" still with Pirelli, Yokohama/Achilles and with SATyre distributors (Maxtrek/Pace/Windforce/limited Goodyear/limited Bridgestone suppliers)
Hugo_za said:Ralf@Speedway Motorsport said:Hugo_za said:I've gotten quotes from BMW for OEM and have also asked Ralf to quote as well.
Non runflats. Need something with a decent price/performance ratio![]()
Ralf@Speedway Motorsport said:Hugo_za said:Ralf@Speedway Motorsport said:Hugo_za said:I've gotten quotes from BMW for OEM and have also asked Ralf to quote as well.
Wow...spent almost an hour on the phone to various suppliers, and this is a difficult size to get hold off, most manufactures do RFT in 19''
sent you a PM !
Gunner-Win said:Yeah it's an unusual size, but I do know of one tyre that will work, the Bridgestone Potenza S001.
ChefDJ said:Keep the standard sizes for ride quality, Hugo. You don't want to compromise when it comes to a 7 series.
Ralf@Speedway Motorsport said:Gunner-Win said:Yeah it's an unusual size, but I do know of one tyre that will work, the Bridgestone Potenza S001.
I was succesfull on Pirelli "Rosso's"
