Tyre Pressure on F30 (19's)
AllyA
Hi Guys. Bit of a blonde question here. What tyre pressure do you guys use on the 225/40/19 (front) and 255/35/19 (rear).
Is it 2.6b all around or 2.6 in the front and 2.8 at the rear.
On the drivers side door the nameplate is abit cryptic with lots of tyre options.
Joe joe
I have run 2.3 front and 2.5 rear , gives good balance of comfort and handling as well as wear , note these are cold pressures , a lot of service station don’t have accurate calibration so best to use the gauge in the tyre repair kit from boot to check before going to fill air
