Hi All,
i pray someone here can help with some knowledge.
my 120d every now and then goes into limp mode, bmw did diagnostics and said its the turbo actuator and they say the entire turbo needs replacing because you cannot buy an actuator separate. for the past 3 months it would only go into limp mode maybe once every 2 weeks. it would go into limp mode as soon as i reached 180kmh, if i decelerated a minute later it regained power. it has gotten worse now as it stays in limp mode Fault code that shows is 4CD0: DDE: charge-air pressure actuator?
can anyone help
Regards
can anyone help
Regards
