Didnt I give you some way back when.
If not I can mix for you again, but I am going to be far too expensive, because I add labour for mixing.
What you do is you call Maroons, give them the color code (available on the side of your door) and they will mix what you want
This will give you spies or something decent
If you want budget, go to paintworks at the bottom of rietfontein.
