Tips - buying a 2nd hand gearbox
ver328i
Hi Gents
Im trying to avoid buying a third faulty gearbox :fencelook:
Is there anyway of inspecting a second hand gearbox before purchase? how will I know whether or not it'l shift into all gears and not grind...
Or is this simply a "buy and hope for the best" thing?
DieselFan
Buy from a place that will honour the warranty. There is no way to check without it installed afaik.
Straight six
Personally i went for the recon route..... its been more than a year now...No issues
When you buy second hand, you pretty much buying "blind" as you don't have history....
You know your gearbox and a proper recon pretty much changes all the vital parts to brand new ones.....
You don't want to be runnning up & down fighitng with shops about them hounouring the warranty and so on if somehting goes wrong
Good Luck:thumbs:
cOlDFuSiOn
Seeing the bad luck you have had I would opt for a recon. You know what's being done and with a warranty from the rebuild company it's probably the safest bet. My 2c :thumbs:
