think my alternators on its way out
e46jase
ive been having a idle problem for awhile now my car idles slightly lower than it should and once it drops to say 500 rpm if i pull off without giving petrol it makes this growl sound and i do have a tear in my lower intake boot which could be part of my idle problem BUT i recently realised that when i put my headlights/fogs on the revs drop slightly almost like the alternator cant handle the load watcha guys think?
nawtiboy
test with a mulitmeter - you will be able to see a voltage drop on the battery.
can be a loose or faulty cable
alternators either charge normally or don't at all
try patching up the tear and see if there a difference
normally the engine automatically adjusts when theres a load
freerider
My money is on that tear, is it before or after the MAF?
Also what naughty said, if it was the alternator you would know about it ;) Also check your battery, has it ever been changed?
e46jase
tear is after the maf its the lower boot think ima fix that up first like you guys said . my car stood for quite awhile and battery died few weeks ago so mayb my battery on its way out its prob pretty old thanks for the help guys :)
freerider
unmetered air going in, and also that battery doesnt sound healthy :)
There was a guy in Australia that had his car on the dyno and it wasnt performing properly, they replaced the battery and he picked up 18kw immediately
e46jase
wow lol i tend to underestimate how many issues a bad battery can cause when my bat died a few weeks back i switched on ignition and my dials started buzzing and i thought id messed something up when i did the kokie mod :( then realised bat was dead charged it and the buzzing went away lolers :clap:
