Johanj
Hi Guys, sorry to dig up a thread again but I have a issue that is bothering me:
My X5 3.0D runs good no issues but after some "spirited driving" or when towing, the temp will climb to just above the half way mark and when driving normal or slowing down the temp will drop back to just below the halfway mark. Is this normal behaviour or should the temp be more constant? can the Thermostat fail in a halfway open position causing it not to circulate fast enough when the engine needs the extra cooling? I have checked in the expansion tank and the water from the inlet in the cap has a steady stream and spurts through when revving it a bit, telling me the water pump is giving good circulation. It does leak a little bit of water, haven't found the exact spot yet but somewhere under the expansion tank, could that be that second thermostat?
