The E46 330i F connecter.
Bmw.wp
Hi Guys
i am looking for where i can buy this piece of plastic cause bmw dealers just have some L shape and not this F shape connecter on they systems. i broke mine when i took out my disa valve thats broken. :cry: and in the process also breaks the small part on the F connecter.
F-Connector
BMW E46 330Ci M54 3.0L
________________________________________
Connects to the air intake boot
This f-connector is located on the air intake boot and provides a connection point for the vacuum lines that run to the brake booster and fuel pressure regulator. As your vehicle ages, heat and exposure to the elements cause the connector to become brittle and potentially crack. As a result, a vacuum leak occurs which can cause poor idling issues, evap fault codes, and poor performance.
Luben
Bmw.wp said:
Hi Guys
F-Connector
On the system the part looks like a "L" shape. The part is actually the F connector that's required, I had the same issue when I had to have mine replaced. I this this is the part number, cost something like R17, 13327503677.
Bmw.wp
naidu_lu said:
Bmw.wp said:
Hi Guys
F-Connector
Spoke to the guy he is going to order it and see if its the part i want. Thanks Bud.:joy:
Bmw.wp
naidu_lu said:
Did u get it as yet?
Check out this link for confirmation: http://www.bimmerfest.com/forums/showthread.php?t=574814
Also, if you we're thinking of buying a new pipe it's around R300, it's not really worth it. Just cut the piece off where the connector broke inside the pipe.
Sent from my iPad using Tapatalk HD
Will do :thumbs: cant wait to hear that 6cyl sound of my baby. :joy:
Parts going to be at they dealership tommorow.
