The strip features tight groupings of LEDs to ensure a seamless glow while maintaining maximum brightness. The most amazing feature of the strip is its unmatched flexibility. The strips can be flexed into a full circle which unlocks entirely new realms of possibilities in terms of builds for your customers while producing brighter more gap-less LED displays. The strip also features external drivers which allow for better heat dissipation and guarantee a longer life span of the LED. We guarantee you’ll be wowed by the new possibilities created using the strips and so will everyone who sees them on your ride!
Perfect for dual function applications. These strips allow you to run a cool white for the parking lamps and then change to a brilliant amber when the turn signal is activated. After the turn signal is deactivated the strips will resort back to white! Strips are sold in PAIRS.
These strips are a simple 3 wire installation:
Red Wire = Parking Lamp Positive (+)
Yellow Wire = Turn Signal Positive (+)
Black Wire = Common Ground / Negative (-)
NOTE: YOU CAN CUT THESE STRIPS TO SUITE THE LENGTH YOU REQUIRE
WHILE STOCKS LAST!!!
