Swirl flap blank off plugs
ChefDJ
I'm not sure if I would trust the putty :fencelook:
I'm too scared it flakes or something and pieces start going into the engine.
Nikhil
Andy also used his existing parts for his swirl flap delete over a year ago and its holding up fine :thumbs: I opted for the blanks tho.
netercol
thats why only from the outside with a selftapper.. must have absolutely nothing on the inside that can come loose..
Solo Man
Maybe should clarify the Pratley Puttey, used the grey fluid one that you mix with grey and clear. Was used to seal it air tight.
DieselFan
The supplier I ordered from sent me the plastic ones. I am going to reorder the metal ones for myself. So my plastic ones will be for sale. It's a set of 6
Sent from Samsung S5
///Moose
The plastic ones work 100% as well, no chance of them melting or causing any issues
DieselFan
Ya I have no doubt but on principle I ordered the metal ones which were significantly more expensive. And so I want the metal ones.
DieselFan
Seller is sending me the correct blanks at no charge and I keep the other ones.
So if anyone needs the plastic ones I have a set for sale. R260 + shipping or collection.
wezza320d
I eventually removed the swirl flaps as one of the screws broke when I checked it. It made a max difference of 0.4 l/100 on my fuel consumption. No blanks were fitted.
