Prini said:Common failure on the E46's are Lower control arm bushes, have them checked out
sclass said:Sway bars don't fail (usually), otherwise you'd be getting clunking sounds. Swaybar links however do wear out. Maybe look into changing those first...swaybars AREN'T cheap...
When last did you change your shocks???
Twinz said:How many Ks on your e46? Shocks/springs are the things that come to mind that may need replacement....
Performance Swaybars & strutbrace will improve handling for sure :thumbs:
tarintino said:Twinz said:How many Ks on your e46? Shocks/springs are the things that come to mind that may need replacement....
Hey Twinz,
she is on 152K at the moment:thumbs:
Legacy said:tarintino said:Twinz said:How many Ks on your e46? Shocks/springs are the things that come to mind that may need replacement....
Hey Twinz,
Then the shocks should be totally pap. There is no way the original shocks has lasted 152k km on our roads in SA.
moranor said:you got plenty choices with shocks you talking to the wrong people tell us where you based and someone should be able to tell you where to go![]()
