Stock vs Xcede E90 MSport 330d
///MOS1TED
Banned
1lum1nat1
What gain would a decat have?
Mos1ted, can you maybe upload a vid some or other time, I'd love to hear that thing?
Would the manual 330d give you better times?
///MOS1TED
Banned
Thanks guys.
Not to sure about the decat thing , but i do know DP will work well from what i was told , didnt want to try cause of warranty etc.
Will try and get a few vids uploaded soonest.
Yeah 330d manual should be much easier to launch with all that TORQUE from low down , in the steptronic its freaking difficult getting it off the line , let alone going against the clock. Manual should be easier to control i think.
Even at the track , it was just wheelspinning and taking off even though i was barely footing it and thing is if you slow on the box it basically says stuff you and does its own thing.
Dmonic1
You can also double shift... (you shift the paddles/gear lever) and the ecu switches at the same time.... LOL, i can hear the excuses now, you gonna sound like an XRsi driver!! :):)
laloosh
Dp n decatt should make a difference but I did read somewhere that on diesels they do shorten the lifespan on the turbo.I don't no how true that is though.
///MOS1TED
Banned
Nope dude the Diesel Steptronic box does not work the same , Sherwin tried as well ....
M
marky8382
MOS1TED can you tell me what you have done to your 330d to get those insane figures? Im considering getting the 330d hopefuuly E90 shape, currently own a Focus tdci and just love the torque you get from modern diesels so you running a 13.9 just make me want to have a slice of that :=):
msm
Thought the opposite was true for the diesels. Someone more knowledgeable care to shed more info ...
netercol
not true, removing the first cat will without a doubt lengthen the life of your turbo, due to a decreased heat load on the turbine side..
