Still loosing coolant - problem diagnosed :(
freerider
On Sat I replaced the Thermostat housing on my car, as you can see, it was leaking.
We went on the breakfast run on Sunday, and this morning when I checked the coolant level, I had to top up about 150ml again :cursin:
Something I noticed when I had my LCAB's replaced in Dec, was that there was hot water dripping down and off the bell housing, so from somewhere at the back of the engine.
I suspect that maybe its the heater hose thats leaking, part number 8 in the diag below.
The crap thing is that its under the intake manifold :bawling:
J
Jandre
I also lost coolant in the same fashion. Turned out to be that exact same hose.
J
Jandre
No, the e36. Just the other day, after we did the engine.
freerider
looks like a mission to change though, I wonder if it can be done without removing the entire intake manifold.
freerider
Found the problem, what I thought was a leak at the back of the engine was indeed water from the aircon, it just gets damn hot after rolling down the front of the gearbox.
My leak however is a bit of a bummer, its the seam of the radiator thats leaking. :bawling:
freerider
Yeah that is from BMW. Really not that bad if you consider my mother paid R2200 for a new radiator for her ford laser 1.3i 2 years ago.
444YYY
For R1750, go quickly and buy it from the stealers.... before they realise there's a mistake on the price!!!!
zaleonardz
Don,
I am convinced that if your prepared to tackle a Vanos job or remove Tappid covers, you can handle this one.... :thumbsup:
