steptronic
BLACK 330
:mmm:After changing my water pump,maybe Im wrong,my gearbox goes into limp mode.Dont know if it is heat related but it only happens after a long drive.Can someone help. (Hope its not serious.):thinker::dunno:
Nic_s
Moved to correct section :thumbsup:
Where did you have the car worked on? Is this a E46/E90?
Nic_s
It's hard to say. With the amount of tech in cars these days, the simplest thing can throw everything off.
Get the codes read (If you haven't already). Might point you straight to the problem.
zaleonardz
There is a tiny possibility but I doubt it.
You do have a cooling circuit that runs through the gearbox, but if you had air in the system you would much more likely have an engine overheat then a gearbox overheat causing it to go into limp mode.
Nic's right... have codes read first.
P1000
Gearboxes often show no errors while they may be completely stuffed. Best is to have a automatic gearbox specialist have a look at it...
BLACK 330
I drove it to work and back (20 km) away,and its ok.So what gives.It changes smoothly in to all gears.:thinking:
