Starting problem on cold days
D
Deeps
hi
i am new to the fourm, and this is my first BMW. Its a 1989 316i, 4 door. i seem to have this weird problem, if i start the car on a cold day, it will start the first time and if i switch it off after a few minutes(before it gets hot) and then try starting it again, it will just swing. After about 20 mintutes, it will start again. i have no problems on hot days, starts and drives well. I have serviced the car, replaced the battery and was told from the previous owner the fuel pump was replaced in the last year.
i have noticed that when i fill 93, the problem is abit better compared to LRP.
the car has over 300 000km.
I also replaced the plastic induction pipe as it had a tear on it.
Any ideas what could be at fault? Someone told me it could be an engine relay?
thanks
Lev
BMW Car Club Member
have you checked the common stuff like distributor/coil/faulty plugs?
PS I'm not really sure of the 316i motor setup, we had that prob with or 325i though.
