spark plugs
operator323
Hi guys,where can i get spark plugs for e90 323i with a reasonable price,the stealers quoted me almost 2k for 6 plugs,and midas R1200 for NGK plugs,m based in western cape.
Luis Malhou
Try Diesel Electric, they should use bosch plugs. I bought the correct plugs for my 335i at a 1/4 of the cost of BMW.
Karthik
I just got a quotation from midas for 6 ngk spark plugs with a 25% discount at 384.75 for the lot. What spark plugs do u guys use?
NFCKN'SANE
Try Goldwagen,
I bought my 335i Bosch spark plugs there - Think R165 each. Exact match part number BMW recommended.
Karthik
Are these the right spark plugs required? Just got this quotation an hour or so ago from midas menlyn.
NAS325ci
Not sure about the spark plugs. I bought an air filter and oil filter from bmw Menlyn auto both came to 307.50 looks like original filters actually priced well
HitokiriZed
Anyone know the appropriate plug for an f22 M235i?
Looking to go a heat range lower - quoted R3k at the dealers :thumbdo:
Dion-ZN
Have you tried buying online from the guys that do stock it. I did that with my 335i plug back then, and saved a lot of money. try www.turnermotorsport.com. the rand is a bit better now too.
Hi Guys
Just to revive an old thread i am also curious about info regarding spark plugs for my e90 325I n52
BMW quoted me R1705 for a set of 6 NGK plugs and these have a life span of 100000km before needing to be changed as per the dealer.
GoldWagon quoted me R110 each (R660 a set) for Bosch Platinium plugs.
What i wanted to know is the difference in price, is it that the agents are just over pricing the plugs or are the Bosch Platinium plugs from Goldwagon just not going to give me the longer service life hence why its cheaper?
Coisman
Administrator
Get the Goldwagen Bosch plugs, nothing wrong with them. My previous set I had for almost 95k kms, no issues, replaced them a month ago with another set of Goldwagen Bosch plugs.
Thanks Coisman
I will order a set from them, thanks for the info especially the life span of the plugs that was my main concern.
MiteshN
Hi, Does anyone know if BMW uses or recommends Bosch or NGK for the F30 320i ?
If I get them from Goldwagen, which one should I go for?
