Slight tank leak
james
At the bottom middle of the diesel tank, there is a rubber type plug. I notice (little)some diesel leaking from there. Any advice what this could be.
AshG108
it is called the over-flow pipe, i am talking from petrol experience but it should apply to diesels as well. if the cars tank is over full or the car parks at wierd or actually steep angles, the petrol or diesel with flow out through that pipe if it goes above a certain level in the tank.
i stand to be corrected on this though since this is a diesel your talking about but i hope this helps
