Hi Beamers, i am running normal tyres. 2004 E46. I cannot get the light to clear. Ignition on position 1-holding button down- stays on. How can I make this go away?
Hi bro, best to introduce yourself and show photos of your ride. As for the tire pressure monitor, ensure you have the correct pressure in all your tyres then reset. It should go away if the pressure is correct in the tyres. If not, then you have faulty sensor. Good luck
That's not correct, when you reset the tyre pressure monitoring it takes the current pressure in your tyres and assumes those are the correct pressures. If your sensors can sense what the correct pressure is then why would you need to reset them? They would just let you know whenever your pressures are not correct.
