Sadly these tyre places are able to "convince" most people to rather replace a punctured RFT than plug it. And then you have the all too common unevenly worn or unmatched tyres on the same axle - since in most cases these people will only replace the punctured tyre.
My logic, if a normal tyre can be plugged, then a RFT is the better of the two to plug in the first place - let's say the repair fails suddenly and allows the air out, I'd rather that happen on RFT's. Okay this is a rare case I would imagine, but with a RFT you have the added safety of the thicker and stronger sidewall, plus with the rim design there is a better chance that the sidewall of the RFT WILL stay on the rim and aid in maintaining control of the car.
But, regardless of tyre type, a puncture repair is always going to be a risk, and requires frequent inspection to make sure that all is fine, no bulging or cracks forming etc...
