Run flat tyres / mages
540buddy
Hi
I have a e90 325i 2009 with Run flat continentals.
Can I replace this with normal tyres or does this not work on the standard bmw mags? If I do so how would I store spare wheel?:hammerhead:
What is the cost of second hand run flats is this even worth it?
Or should I just in buying mags and tyres for my beemer to get away from Run flat technology?
Thank you
SlimmJimm
Howsit man, yeah u can use normal tyres but then have to put a spare in the boot......i think a bottle tyre jack could be handy too..... What tyres u looking for i can maybe get a good deal for u on runflats
Sent from my E6653 using Tapatalk
540buddy
Hi there
Tyres are still good - continental 225/45/17 - not in need now.
Is you price based on new or second hand - what the R?
Where can I possible get a key for my lock nut on my standard mag wheel
SlimmJimm
New tyres.....whatever size u want i can give u a quote, excludes fitment and that but u can do that anywhere....i am based in JHB south.
For the key i have no idea, probably have to try bmw or maybe tyre fitment places can help u out?
CK4LIFE
I got same size mate n might need new rear ones in a month or 2...will pm u in due course, based in PTA tho.
Schalk94
Runflats are actually not that expensive in 17 inch sizes. But you can fit normal tyres to the car too,the ride would actually then be a lot softer and more comfortable than with the RFT tyres.
ramjee13
You can most definitely put normal tyres, you'll have a much smoother ride, only downside you'll have to get a spare. i got myself a space saver (biscuit) spare so i still have a boot. i seen one for sale in the parts section.
ET was here
you can also try out the aftermarket run flats such as Pace, they are sometimes a good 30percent cheaper than conti's
try SATyre distributors in cape town
tman
540buddy said:
Hi
Thank you
I have non runflat tires on my E90. The ride quality has improved a bit, and they are cheaper. Only downside is you need a biscuit or a full size spare wheel if you going this route. I dont mind tho, as I barely ever use my boot, and I have peace of mind
