Once again, a very long over due update, and boy have I been busy!
Picking up where we left off:
6 August 2019
161 5xxkm
Carly
Coded Rain Sensor Back on
Coded Rear Windows one-touch up
Coded Electric windows to work with door open and ignition off
Coded Wipers to complete cycle after ignition is switched
I bought a Carly subscription to test it out and coded a few random things to make the car a bit more optimised.
Then the washer pump started leaking, so I replaced it.
10 November 2019
164 942km
DIY
New Windscreen washer pump (FEBI)
19 November 2019
165 294km
Brilliant Mechanical Workshop
Oil Service (LM Molygen 5W-40)
Install new Front Shocks (Koni Special Active), Shock Mounts (OEM)
Install new Front Lower Control Arm Bushings (OEM)
Install new Rear Shocks (Koni Special Active), Rear Shock Mounts (Lemforder)
Install new Brake Pressure Sensor
Brake Fluid Flush
Install new Windscreen Cowl
Then came the next batch of work which was really excited for.
I was most looking forward to the installation of the
Koni Special Active shocks that I bought. I am so impressed by these dampers, they offer improved ride comfort with very little trade-off in handling. For me, it is the ultimate setup for a daily driver that made the car more comfortable than before, but the car still performs exceedingly well on a mountain pass (it has no problem keeping up with my Z4 in the grip / handling department).
It was also time to replace the ageing windscreen cowl with a new one.
25 November 2019
166 xxx km
New Bonnet BMW Roundel (OEM)
Headlight Lens Restoration (Zeetech Customs)
Revitalise Detail (Mike Flynn)
Next up was some more cosmetics, including something I had wanted to do for ages - restore the headlight lenses. Finished off with a basic detail from a local detailer.
Old Roundell (note this was not an original BMW item which is why it is so badly degraded. Rest assured, the new one is OEM:
I also replaced the rubber trim around the headlights.
Old, dirty, nasty:
Cleaned and new rubber installed:
I also bought the new trim piece that goes above the headlight. And here you can get an idea of the refurbished lenses.
Front all put back together with new roundel, restored headlight lenses and new headlight trim:
5 Feb 2020
Express Auto Electrical Repairs
AirCon Regas
The AC started making a slight hissing sound every now and then through the vents, so I had it re-gassed and check for leaks but no leaks were found. After re-gass, the AC blows ice cold and hasn't given any issues since.
15 June 2020
Retrofitters
171000km
Rear Number Plate LEDs
I also fitted some white LED rear number plate lights, but I forgot to take a pic.
13 August 2020
Luigi's Dent Removal PDR
Next up, was PDR by Luigi who has done miracle work for me before. In this case, no miracle work was needed, just a few tiny door dings to take out and as usual he did a great job.
6 November 2020
175 015km
Coolant Flush
New Fuel Pump (VDO OEM)
Oil Filter Housing Gasket
New Alternator Voltage Regulator (Bosch)
Sticking to my annual / 10 000km service schedule, it was time for another service. This time I chose to replace the Fuel Pump and Voltage regulator as a preventative measure, and the Oil Filter Housing Gasket had a slight leak so that was replaced too.
9 November 2020
L&Z Auto Centre
175 086km
2x Michelin Pilot Sport 4 (245/40/17)
The time came around for new rear tires, and only the best - Michelin Pilot Sport 4! I just love these tires so much.
14 Dec 2020
BMW
New Steering Wheel (OEM)
New ZHP Gearknob
New Leather Key Cover
So this is where things really start to go to the next level. I decided that I wanted to start getting the car to the point where I had always dreamed of - in other words - as close to like new as practical and possible given that its a daily driver and that I'm not a billionaire.
So, something that I have found extremely satisfying to do on my other vehicles is replace the steering wheel. I chose to buy a brand new one from BMW because I wanted the new plastic trim and buttons, as well as factory perfect quality. Ironically enough, the first wheel I got from BMW was not good enough - there was bunching on the leather in certain places that were not becoming of a factory part. So I sent it back and BMW replaced it with another one which was more in line with factory quality.
I have to say, it really makes a huge difference when you drive this car having a brand new steering wheel. It feels like a new E46. To complete the look, I replaced the Gearknob (again) with another new ZHP one just so that things would match.
Lastly, I replaced the leather key cover that I always have on my BMW keys as the old one was getting rather worn from living in my pockets.
Here's the first wheel I received, notice the wrinkling of the leather near the button cluster
Outgoing steering wheel (still in good condition for its age)
First new wheel installed, again you can see the wrinkling on the left side. Not satisfied given what I paid.
Second time around, the wheel is better and acceptable:
22 Jan 2021
TWT Bellville
176 634km
2x Michelin Pilot Sport 4 225/45/17
Time for new front tires.
Random Car wash photo
