Captain_Stealth
sash said:of course we are interested in builds like this
Parts I have:
4mm rack spacers
25mm wheel spacers
BC Coil Overs
Modded uprights 20mm shorter
Poly Bushes - Power flex black series
New Tie Rods
e46 wishbones with e46 wishbone 60mm bushes
Adjustable Rear Arms
Hydro Hand Brake
330i Front Brakes
325i welded Auto Diff (3.64)
Silicone hoses
Elec fan with switch
Alum Radiator
Cone Filter
Rear top shockmount support
Rally Rear View Mirror
sparco tow straps
light weight under drive pulleys
Magnectic Drain Plug
Door Handles straps
5" Tacho Meter
solid steering bush
Single din cubby
Light Weight Mirrors
Suede Steering Wheel
Light Weight door cards
Weight reduction
Wheel Stud conversion
Weighted Gear Knob
Brass Radiator Bleeder Screw for radiator
Wish list - collecting some parts on payday lol
Front Strut Brace
Racing seats
Solid Caliper bushings
Lexan Windows
manual window winders
bonnet hood pins
management with wideband
e36 m3 engines mounts
steel brake hoses
e36 318is radiator switch
e46 m3 gearbox mounts
front subframe reinforment plates
front strut towers reinforment plates
rear sway bar / swaybar tabs reinforment plates
rear camber arms reinforment plates
535i shifter
Shifter Bushings and rod
Bigger Front swaybars
X Brace
e36 z3 steering rack
Red Angle Eyes
M3 Bumper and rear difusser
fuel cell
Steel clutch line
roll cage
This exclude my motor build bwahaha
