Right window not winding up fully - GSpec M3 '95
ClassicB
You need to reset the window.
Look where the lock actually latches when you close the door, you will see a small black button type thing. If you press it you will see window will move down a quarter inch.
Press that once then go into the car and press the window switch as if you closing the window. Then back to the black button. Repeat this process until the window goes to the top.
Which area are you in? because i can do it for you if you dont come right.
Millas
IT WORKED 100% THANK YOU SO MUCH!!!!!!
:praise::ty:
