MSB135 said:
Hey guys
I looked at the bms installs, do the rhd guys still mount the jb4 in the same spot?
Or where are the best space. The space is limited in front of the driver side because of brake booster etc.
Do you guys still mount it somewhere there or not
Mount it at driverside.
positive connect to positive jump start pole, loosen the nut and wire around and screw the nut back in, same for negative, it all at driver side.
positap for canbus is at passenger side. under a cover.
and every other sensor the cable will reach.
even with the brake booster there, u should still able to to strap to the metal bar with cable tie like the picture.
