How do I remove oil pan e90 BMW 2.0
ray.dummer Active member Jul 24, 2016 #2 http://www.e90post.com/forums/showthread.php?t=585855 Very labour intensive job....rather take it to someone who has a lift.
W wonderB New member Jul 24, 2016 #3 Thanks man..I will jack the engine a little myself and see if it's possible.
ray.dummer Active member Jul 24, 2016 #4 Ok, cool, just remember you need a support bar on top of your engine when you remove the lower support frame
W wonderB New member Jul 24, 2016 #5 I managed to remove the oil pan..but I just jacked the engine from the gearbox all up and the removed the left hand side engine mounting and swivelled it a little and it came out..I have now took out all pistons..
