Redline 5W50 for e46 m3
shauwn
Howzit, saw a video from Yevs builds where he used 5w50 engine oil, he said its thinner and helps with better lubrication for rod bearings vs normal 10w60, any thoughts
Richard H
Yes 5w50 is the oil of the future, I have been using it on X5M, I use the Ravenol 5w50 available locally
Veedub
I still can't understand why anyone uses a '10W' oil in the M's with known bearing clearance issues. '5W' should be the highest - and please don't say that it's what BMW recommended, cause they the same people that designed the engine with too little clearance in the first place. For our climate, '40' is more than sufficient, with 60 for track days. I suppose then that 50 sits nicely in-between. Anyone noticed any difference in oil temps when driving hard between a 40, 50 and 60 oil?
Richard H
My thoughts exactly
Richard H
Would love to try this but it's so expensive!
Crash_Nemesis
5W is good for oil clearance on a cold engine and if you daily the car and you do not intend to drive it hard.
10W was designed for when the engine gets hot during continued high RPM pulls. The 5W weight oil will become too thin after prolonged hard runs and ultimately break apart and be consumed faster, thus not being effective at cooling and lubricating the pistons and bearings, hence why the 10W weight was chosen.
I have driven with both oils in my car for extended time (11 years experience both street and track driving). I noticed more ticking from 5W oil. The 5W oil did warm up slightly faster for street every day driving and oil temps were higher on track. As you may know, the bearing clearance on the S54 is very tight, hence the continued discussions of possible reasons for premature bearing wear. My suggestion would be to continue using the 10W-60 but to do oil changes more frequently, say every 10K km as opposed to the BMW suggested 24k km.
I see a lot of guys who do not own e46 M3's posting about using 5W oil. Just because it works on one car does not mean it will work for another.
In short, 5W is safe to run for daily commute and the odd hard pull, but be aware that it will heat up faster. I also noticed much higher oil use using 5W and had to top up.
M3boi
10/10. I run Motul 10w60 in mine and the temps are a lot more stable when pushing it. I'd rather keep the revs below 3000rpm with light throttle usage and let my car warm up completely before having some fun and know it can withstand the higher temps a lot better.
Richard H
I agree 100% and like you said track use 10w60 is great
momo1
+1 I do exactly the same
Dax
If you set up a motor for race conditions "Bigger bearing clearances" then 50 or 60 is better to use.
Clint@MMS AUTO
I use the LM 10w60 with the optional anti friction additive and service every year or 2500km max for extra peace of mind . then again I track my car and when I use it , I use all 8000rpm of it.
Personally I’d never feel comfortable running the motor under extreme load with 5w oil in it.
shauwn
havent had any oil loss using normal 10w60 liqui
