Pho3niX90 said:
Serpentine belt if the steering is also causing issues. Don't drive it.
Red batttery means that the battery isn't getting charged.
double check on this
snapped/broken belt
Battery light means the Alternator isn't turning and charging the battery
Also driven by the same belt is the power-steering pump, hence the stiff steering
apart from difficulty steering, nothing is charging the battery anymore, and once the battery gets flat, thats it...stuck
should be a reasonably easy fix....but don't drive it for now !
