Recommended mechanics JHB east for diesels
shark111
Hi Fanatics,
My 320D is feeling very down on power and has started sounding different recently too. The power loss was first noticed after I had my mechanic change the damper pulley and belt, however I can't see how that could have caused this. I've also checked for codes and found none. The car was at BMW for the oil service special too and they didn't report any issues.
Which are the recommended BMW diesel mechanics in JHB East? I need someone who can diagnose the problem..
Thanks!
Sent from my Mi MIX 2 using Tapatalk
shark111
Nikhil said:
E90? E46? What year model and where in Jhb east a little more detail would help.
Sorry, it's a 2009 E90 Auto, I'm in the Edenvale area, but don't mind driving till Alberton or Springs.
Danny2
I’m in Edenvale, have the tools to scan the if u want me to have a look I don’t mind helping
e46monk3y
Events Organiser
Give Tune tech a call, they're based in Judith's Paarl, just down the road from Eastgate.
Good luck pal :=):
AndreX
i usually send my car to supertek they are close to the Rand airport. i have never had any issues with them and they are RMI approved so they can do warranty claims if you have a aftermarket warranty
only problem is you need to book about 2 to 3 weeks in advance as they are always super busy but the prices are good as well. :dunnoanymore:
My 2011 E90 320d also had a bit of power loss but mine was sorted out after replacing the boost seal on the charge pipe. Not sure if that was the cause but it has been running like a dream again ever since :fencelook:
Good luck mate! :thumbs:
shark111
Thanks for the recommendations gents, been crazy busy so haven't been able to have it checked out yet but its gotten worse so definitely need to do something.
Drove my bros E90 320d with the 135kw engine and the difference feels way more than 5kw and more torque so something definately up.
The mileage is at 160k now, so thinking I need to decat anyway if it helps with turbo life.
Danny will PM you so I can come over to you :thumbs:
Supertek is also literally on my way to work so will try them as a second if we can't figure it out
shark111
So I was at a friends place who has a snap-on OBD2 tool, scanned the car and found no issues.
Eventually decided to set the snap-on to log and took the car for a drive, logged about a 10 minute drive and nothing obvious came through the data.
Next up, going to call Supertek and take it in, was thinking of Ross Duncan but its difficult with logistics working in the east!
VinceM
YUBEN said:
Gizmo is in Alberton, works on diesels :thumbs:
If it’s a big job,
Check with him in 2 weeks, Ridwaan’s and my car (both 330Cis) have been with him for a while. There is another car there too. The man is busy
shark111
MSLVIN003 said:
If it’s a big job,
Thanks bro, at this stage not sure if its a big job, just need someone to diagnose and then can see from there. I'll try Supertek first, otherwise I might take it to Nige Auto in Benoni as my cousin is good friends with him.
