Rebuild or Engine Swap
nabeelm07
Thanks a lot. Im leaning towards resleeving the block and replacing the piston rings as my pistons are still good to go. The Engineering shop here in Durban says they have done many N52 blocks by resleeving them and not a single comeback, so will take a chance with this one as I have already spent 15k to redo the cylinder head.
Appreciate your advice.
Hi, just checking if you ever ended up reserving the block and what the results were?
