Rear Brake light warning sensor stays on
shaunnorth
@pump_upp - best crypto pumps on telegram !
Hi Guys
I dont if this has been posted but i have found the soution to a comom bmw E46 problem on ur dash it shows that ur rear tail/brake ;ights are blown but they are working fine do ur self a fav check the licence plate bulbs and the warring lights will go away if they do not u have grounding problem in the boot
Sankekur
Sometimes it is also caused by older bulbs then you just replace bulbs one at a time till the warning goes away.
shaunnorth
also it a good idea to get test meter the check the wire in the rubber boot that joins the boot lids wireing they tend to brake off over time opening and closing the boot that how i solved my waring light issues
msm
Check the condition of the ground wire (I think it's brown) and the connector - sometimes this connector corrodes a bit due to the high current and needs to be cleaned.
Iceman007
Buy the plugs and pins from BMW and do the modification as sugested by BMW on both lights. Yours are probably burnt contacts due to a desing error on all e46 models and cused by to much current on the thin earth wire. Ad an extra earth wire to the body and the light holder. Check this link
http://www.bmwtis.com/tsb/bulletins/bulletin_graphic_temp/B630306g.htm
http://www.aboutautomobile.com/Investigation/2004/BMW/325I/Tail+Light
Note:
On all the E46 models I have worked on the numberplate lights does not show on dash
shaunnorth
numberplate lights were my fault on mine i think if both are blown then it will show
Hoffi
i've got a similar problem. but mine is intermitant it doesn't give the warning all the time. do you think it's the same ground that would be responsible.
shaunnorth
do ur self a fav coz that how mine started there is rubber boot that is atched to the boot lid and the car what happed to mine was some of the wires broke off rejoined them problem solved the the ground is a good place to take a look
