R56 Jcw Dropped, Thanks Axis
Dean ///M
Limited Profile
He was the only guy who could supply me with only front H&R springs. Remember my problem with all the sound in the trunk that it picked up the front so much more. Last Friday I did a quick glaze with Menzerna products fitted the springs and used Foliatec spray film on the wheels. All done in 9Hrs. Here's some pics. Will drive her properly & report back on handling.
Dean ///M
Limited Profile
The ride is a bit softer but I believe that it hardens up around the bends. They too part of the coil is soft but I believe that's how they are made for comfort and handling kind of progressive.
Jarv
Thanks Dean.
Il be ordering in October, spoke to my manager today at bmw , I can put the springs in.
Does it lower by 35mm?
Dean ///M
Limited Profile
It drops 30mm exactly to the mm I measured before & after couldn't believe it was the same both side cos normally the Lhs always sits higher: before pic:
Jarv
Cool thanks Dean.
Nice pics!
I somehow thought the H&R was 35mm? Anyhow il order a set in October. ;)
Jarv
Hi Dean.i looked at your pics again, how much lower did it drop cause it looks similar to the standard height?
Or are the 1st pics you posted of how it looks with the drop? Cauae that looks niiiice!
Dean ///M
Limited Profile
Yes first pic's is with the drop but note that I only did the front. Rear is lower than stock cos of sound install in the trunk.
