husaindindar
Gents.
So I get this vibration coming form the center of my car(E90 325 150000km), only when accelerating . When coasting or decelerating there's no vibration.
Also when rolling the car in gear or reversing, there is a loud squeak like some rubber is worn out. The squeak happens at the prop speed (faster than wheel speed) and goes away when I shift to neutral.
I'm currently assuming it might be guibo or center bearing. Is there anything else that I need to check out?
Any other rubber joints that can wear out on the prop?
Visual inspection of the guibo doesn't show any cracks or doesn't look worn out.
Trans mounts are all good also.
Thanks guys!
Thanks guys!
