iifunky said:
you need to have the thermostat removed on those cars to protect ur motor.
I can't believe there are still clowns that post this crap, then newb members actually do it.
for goodness sake, NO CAR SHOULD BE DRIVEN WITHOUT A THERMOSTAT!!!!! Your oil heats up too slowly, and in most cases NEVER gets up to operating temp, your car over fuels, your combustion is incomplete, rings wear more quickly and it promotes blow-by and oil contamination, valve guides wear out and there is more strain on your oil pump.
In short, IT'S BAD!
Arbee said:
At present, I need to replace the Powersteering pump and pipes. And the LCA's. Quotes ranging from 15k upwards. :tease:
However, the car is moving and i dont have time or money now to sort it out.
Unfortunately there are some issues with R53 Minis. Suspension bushes wear out, PS pump failure, wheel bearings don't last very long, crank seal can start leaking oil, cooling expansion tank and thermostat housings crack. But I took this all into account when I bought my car.
Don't replace the whole LCA, its not needed. Is most likely only the LCA Bushes that are worn, I replaced mine at a shop for R1050 per side. But the ballpoints could also have been damaged if it was driven wit worn bushes for a while. I would recommend you do this quickly as braking performance is massively reduced with worn bushes.
Or buy a kit like
THIS and let someone fit it for you. Then your front end will be tight again.
As for the power steering, I decided that is my pump fails that I would fit a PS Pump delete kit (like
THIS). It makes the steering noticeably lighter that one with a dead pump apparently, and doesn't cost much. You can use this as a temporary fix or a permanent one if you don't mind heavier steering IMO.
Just a few options.
Regards
Jacques
