Problem found but new issue
Thunder
So me and Ramo3n found what pulley is making the noise, found it to be the aircon clutch.
Removed the fanbelt running that plley, noise gone.
Now this morning after the 3 or so start my inspection light comes on.
Car was serviced a month ago and computer was reset and everything, why would that light come on?
Is it due to the fanbelt not being on or is it something else?
Sent from my GT-P6200 using Tapatalk 2
Twinz
Forum - Support
Glad one issue was identified. I absolutely no idea what could cause the service light to come on.
Try reset the light and see if it reoccurs.
Thunder
Been thinking the same thing but dont just want to reset the light and then it came on due to something else that is wrong.
Rather try and find out.
Twinz
Forum - Support
The service light could be due to the past service that was done and the light was not reset at the time...possible? Do an onboard computer check of the vitals such as oil/water/electronics...it should give you an idea if any services are now due
Thunder
I reset it the day i did the service like usual.
How do i do that?
D
Dippies
Bruce i don think your car can do that :fencelook: mite be wrong but i don't think so.
Thunder
Thats exacty why im asking, ek het nie die een in met die groot comouter in die kar vir al die readings en goed nie.
Twinz
Forum - Support
Aah...then you need someone with a diagnostic cable to check & clear it :thumbs:
ChefDJ
Thunder said:
He might not charge just to have a look at it for you. If you want, call the workshop tomorrow and explain to him the problem. His name is Deon. Workshop number is 011 822 4244
:thumbs:
Ralf*
hiya Thunder
do you need the computor and cable, or the reset tool that fits into the socket located in the engine bay.
My friend that does most of the maintenance/services on my 2 cars, lives in Terenure (Loop or Looper str...or something like that) and he can do the reseting of the service indicator......if that is what you are wanting, and he will probably not ask anything if I refer you to him ?
Thunder
Romeo E.T. said:
hiya Thunder
I can reset it myself no prob, my prob is I dont know why the light came on for no reason after we removed the fanbelt running the aircon.
Does the electronics pick up the aircon isnt running or what the hell?
ChefDJ said:
:thumbs:
Thanx.
Can I tell him I got his number from you?
ChefDJ
Thunder said:
Thanx.
Sure thing. Don't say Daaltjie cos he'll think you belong in Weskoppies :roflol: Tell him Dyllan referred you
Ralf*
strange indeed, I wouldn't have thought that the E36 model were that computor sophisticated.
I also removed the aircon belt on the E36 325i (1993 model) I used to own because the aircon compressor was packing up and blowing fuses, as well as the belt tensioner pulley was also screaming loudly, and about to seize.
but it made no difference to the service indicator lights though
Thunder
Thats why I took it of, but mine is the pulley on the aircon itself.
Mine is the 95 318i.
