powerflex lcabs in the lollipop
they come without the lollipop, but i am going to look at doing a swap out scheme where i will put them in the lollipop and members can ship them back to me to get a deposit back :)
it will help people alot that want to DIY this... if you going to get them fitted in a shop there is no need to get the lollipop because they press out bushes all the time :rollsmile:
freerider
Mmm, yes. The problem is finding a shop that doesnt hack your ball joints to pieces while trying to remove the old bushes.
but this is a general problem if you let others work on you car... they fix some things and damage others :rollsmile:
freerider
I just need to have a look and see if mine are the off center hole or not, seems to be some confusion because of the motorsport suspension.
i would get some lollipops and have the old bushes pressed out to save time... i only have e46 lollipops right now so if you get some i will buy your old ones off you :rollsmile:
Hellas said:
Does the E46 lollies differ from the E36?
e36 are steel and the bolt pattern is different...
E46:
E36:
images
