Power Steering Problems X5
Le Boss X5
Hi Anyone can help me
Power Steering is turning harder as before and sticks at times
Where can I get a replacement pump or can this pump be over hauled
Many Thanks
Nic_s
And check the belts. It might be slipping. Not sure if the X5 has tensioners, but I think it does which you should also have a look at. If you can't remember when they were last replaced, then they probably need replacing depending on how old the X5 is.
Raybimmer
Is the power steering fluid level dropping , are there any leaks?
If you have a steering rack that is worn you would have fluid leaking into the rubber boots , and if they are torn or cracked you then lose fluid there .
Good luck .
Le Boss X5
Thanks so much - took it in today and looks like the steering rack needs service and fix and when they checked it from left to right on the hoist it made a rough squeaky noise. R4490 - to overhaul
