Possible clutch or slave cylinder on its way out?
Jarv
Hi Guys
Iv been recently hearing a noise like wooot sound every time I let out clutch, it doesn't happen all the time though.
I was thinking it could be a slave cylinder
What do you guys think, car only has 37k on clock surely the clutch shouldn't give problems already.
Jarryd
Ralf*
Jarv said:
Hi Guys
Jarryd
any other symptoms other than the "wooot: sound ? ...like the clutch pedal going soft, or the clutch juddering, or the clutch not disengaging properly, or fluid usage (needing to top up fluid) etc etc ?
personally I think that the boot covering the clutch pedal actuating arm, might be perished or have a hole or has come adrift, and now it is entrapping air, and causing a "reed-instrument" musical note as air is sucked into or pushed out of the dust boot
my opinion only
Jarv
Thanks man.
Yea car is booked in for Tuesday the 20th.
Yes car on m/plan
